Pipe support Catalogs, Metric and Imperial
duncanfenwick
duncanfenwick
I want to add some block based Pipe Supports a catalogue for use in metric and mixed metric projects.
Do I have to create imperial and metric blocks to put in each catalogue? I don't really want to duplicate.
Thanks.
h_eger
No, it is not necessary to create user-defined supports in mm and inches, as you have to decide whether the units are in metric or imperial when creating them in the Speceditor.
However, the supports can be used in both units of the project specification.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
duncanfenwick
So if the Blocks i get are in Imperial put them in Imperial catalouge and Metric in Metric catalouge? I can then use them in any unit project?
h_eger
Yes, so please implement
Hartmut Eger
Senior Engineer
XING | LinkedIn
duncanfenwick
So I added custom metric support blocks to the "SUPPORTS Catalog metric.acat" added them to "PipeSupportsMetric" copied pspc, pspx  over to 2 test projects, a "metric" and a "mixed-metric", they don't show on the tool pallets.
If delete the "PipeSupportsSpec" pspc and pspx and rename the "PipeSupportMetric" to "PipeSupportsSpec" etc they don't show.
So what is the point of having "PipeSupportMetric" I understand having to catalogues metric and imperial and adding them to one spec, but Plant only sees "PipeSupportsSpec" so no point adding anything to "PipeSupportMetric" in spec editor.
h_eger
You can insert parts from different catalogs in your PipeSupport Spec so it works
Hartmut Eger
Senior Engineer
XING | LinkedIn
