AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe line numbers on bill of material
2 REPLIES 2
aquaphil
310 Views, 2 Replies
Does anyone know how to get the bill of material report to show the material by line number. I can get the line numbers to show but items that are on multiple lines show only one line number. For example on the attached the 12" pipe is on two different lines but the report only shows one line number.
2 REPLIES 2
jabowabo
in reply to: aquaphil
You need to add a sort field for line number in the report layout editor. You should have a sort field for every column except quantity.
Its not the answer to the question, but you can get a BOM when you run an Iso each time. Look in the options, you can save a CSV, XLS or TXT file of the BOM each time you run the Isometric.
