AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe alignment
6 REPLIES 6
2864 Views, 6 Replies
Pipe alignment
I have two pipes that I can not get the T and Elbow to align.  ALl it has to do is rotate the fittings to the correct angle and it will not do it.  It says that it cannot find any paths.  Why will it not do this simple task?
6 REPLIES 6
h_eger
demonstrated a way here
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
What is 'LOT' in whatever language that is?  What command do I use?
h_eger
Sorry was my German version.
B = P for Plane
LOT = PER for Perpendicular
Hartmut Eger
Senior Engineer
XING | LinkedIn
in reply to: h_eger
This got me there.  I still had to put the T in half way through my lateral and then move it in line with the vertical because It did not put the T in automatically.  But at least this got me to the point of where the lateral line was running directly to the vertical.  Thanks.
in reply to: h_eger
how did you get it to display angle when constructing pipe?
in reply to: h_eger
hi, can you help this  problem, see attached
I want to align the end pipe from crossing pipe so that can connect each other.
Technology Administrators
AutoCAD Beta
