PH IMPERIAL BOLT SET issue
jsminkert
Message 1 of 10
jsminkert
I'm having an issue with plant 3d calling up my bolts in my spec for ISO generating. It is pulling in a generic call out for bolt sets related to 300# flanges...I've checked diameters and lengths in my spec and they seem to be correct. It's really odd because my 600# flanges are calling  up the correct information from the spec. I've compared the two and everything seems to match so im not sure why it's doing this. I've combed through the project set up manager and haven't seen anything obviously wrong but I'm certain im missing something. Has anyone else had this issue? What exactly should I be looking for and where do I find it? I'm currently using plant 3d 2026 along with its spec editor. All of the specs used are custom specs, not the ones stock in plant 3d spec editor. I'm stuck, and I have 70 ish ISO's to run and I'd at least really like my BOM to come in correctly.
Any help or suggestions would extremely helpful and appreciated
Thank you
Replies (9)
Message 2 of 10
h_eger
@jsminkert ,
Remote diagnosis is very difficult in such a case.
I suspect that some parameter for your Bolt Set #300 is incorrectly set in the catalog or pipe spec, which is why the desired Bolt Set #300 is not being used for your flange connections.
We need more information about this Bolt Set #300 from your catalog and pipe spec.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 10
jsminkert
from the spec 300# that is coming in wrong
from the same spec for 600# that is coming in correctly
snip it of the ISO BOM
Initially I thought there was an end type or grouping issue inside the set-up manager google searches rendered a setting to replace bolt sets from default to spec....but I couldn't find anything resembling that in the setup manager, So is looked into the ISOcongig.xml and couldn't find anything there either
Message 4 of 10
h_eger
1. Why are pressure levels #300 and #600 combined in one pipe spec?
2. Why is there a Part Use Priority setting for the bolt sets?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 10
jsminkert
I dont really have an answer to that except its the clients pipe spec....not mine. In this particular case there is in fact a 600# actuated control valve  in this line...IDK why, doesn't make a whole lot of sense to me but, there is and they don't want to replace it.
I set the priority hoping that might fix the issue. It clearly didn't
This bolt call out issue is consistent across all of the lines including those in other specs. not just this one. It blows my mind that for this 600# bolt set plant 3d is calling up the correct information but can't do it for 300# or 150# sets. I don't know why i've gone through all the things I know to check here. I'm working with 6 specs and 25 to 30 ranging between 150# to 600# and a few mixed with all three. It's just the way the client structured their specs. All this work I have about 70 ISO's and the issue is persistent throughout all of them that contain flanges.
Message 6 of 10
h_eger
I would inform the customer that his pipe spec is not working correctly and therefore the ISO cannot be created properly.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 10
jsminkert
Well that doesn't really help the situation.
Is there a setting in the set-up manager that I may have overlooked?
Message 8 of 10
h_eger
It doesn't help either, because without the necessary information we can't help!
Pipe Spec
Catalog
DefaultConnectorsConfig.xml
Or how do you imagine assistance?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 10
andrewchawen
This is a common headache in Plant 3D ISO generation, especially when using custom specs. Since your 600# flanges are pulling bolts correctly but 300# aren’t, the issue usually comes down to how bolt sets are mapped in the spec and ISO style setup. A few things to check:
  1. Spec bolt set mapping – In your Spec Editor, confirm that the 300# flange has the correct bolt set size mapping in the Bolt Sets tab. Even if diameters and lengths look fine, sometimes the “Bolt Length Calculation” or “Bolt Selection” rules differ between classes.
  2. IsoSkey mapping – Check if the IsoSkey assigned to your 300# flange in the spec points to a valid bolt set in the IsoSkeyAcadBlockMap.xml. If it’s generic, it will call in a default/generic bolt note.
  3. Bolt Calc Settings in Project Setup – In Project Setup → Isometric DWG Settings → Annotation and BOM Settings, verify the bolt length calculation style. Sometimes custom specs don’t fully inherit the correct rule from the stock spec, which causes ISOs to pull a generic annotation.
Message 10 of 10
jsminkert
Thank you, this helps a ton
