AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PDF refuses to properly convert to DWG any ideas why ?
5 REPLIES 5
mailZU2NV
492 Views, 5 Replies
I have this pdf which once converted to DWG by PDFIMPORT becomes like on the photo below. I don't understand why, is the quality too low ? I have successfully converted similar quality pdfs, should I upload the PDF as separate file ?
5 REPLIES 5
mailZU2NV
in reply to: mailZU2NV
In case you need it, I will upload the PDF as well.
The PDF document has been scanned rather than created directly from a CAD package. This means it contains only rasterised pixels rather than any line information.
mailZU2NV
So I am out of luck here ?
You could bring it in as an underlay and trace over it...
Slawomir_
AutoCAD Raster Design could help in this case. You can vectorize raster image. Remember: accuracy depends on raster image quality and resolution.
Technology Administrators
