In project property.
Is it possible to add fields in the update parameters of piping specifications?
for illustration see attached file.
Best regards.
If you add your properties in 'Plant 3D Class Definitions' from the project settings, they will show up also in the 'Spec Update Settings' section.
OK, I see what you mean now. Not all properties show up in the Spec Update Settings. 'ComponentDesignation' is one of these. Im not aware of a way to add these properties into Spec Update. The spec update properties are actually listed in 'ProjectSetupSpecUpdateSettings.xml', but directly adding ComponentDesignation into this xml file didnt add it into the project Spec Update dialog.
