P3D Timestamp Convert Format
jgarzaM6SUZ
Message 1 of 12
jgarzaM6SUZ
I am trying to write a report via SQL to pull all the locked lines and also the timestamp column. I have been trying to research the timestamp format and have not been able to determine the format. Just seeing if anyone has had a run into the same situation and figure on how to convert it.
Jorge Garza
Replies (11)
Message 2 of 12
MateusMaciel
Message 3 of 12
jgarzaM6SUZ
@MateusMaciel , I have looked at several posts just like this one, but the source format needs to be known in order to convert to the proper format I need. Like in Data Manager it displays like "10/22/2020 1:15:18 PM" and in the table it shows as follows "637389873180923485". Nothing that I have tried seems to work.
Jorge Garza
Message 4 of 12
DVaquand
Hello
Here is a link to find the date from the timestamp attribute
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
Cordialy
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 5 of 12
dave.wolfe
I used this formula in PowerQuery: #datetime(1,1,1,0,0,0)+#duration(0,0,0, [PnPTimestamp]/10000000)
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 6 of 12
jgarzaM6SUZ
@dave.wolfe  Thanks I will actually try that, since I am using excel and power query for the data after I write the sql views.
I did notice that it’s using the scientific notation formation, will this formula resolve that?
thanks,
jorge garza
Message 7 of 12
dave.wolfe
Yes, I created a custom column to hold the value.
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 8 of 12
dave.wolfe
FYI, if anyone cares, the value is an int 64 not a normal SQL date/time value, so it has to be handled in a special way.
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 9 of 12
jgarzaM6SUZ
@dave.wolfe Yes, I do. Trying to determine what an int64 has to do/ handle for an cell entry? Might need to explain that to me in more detail sometime. Thanks fir the help.
thanks,
jorge garza
Message 10 of 12
jgarzaM6SUZ
@dave.wolfe
Any idea why the date time stamp would be off 6 hours. I have checked the sql server and the file server for date and time zone and its all correct.
Message 11 of 12
dave.wolfe
It's probably storing in UTC.
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 12 of 12
dinant
I'm looking into the same.
I found in the Autodesk help a excelfile to convert the timestamp to a readable format.
Not only is the hour off (But related to UTC it is correct)
But when i fill in the full years i get the year 3624 in stead of 2024.
In the new projects the timestamp starts with a 6, in older ones (2014/2015) the timestamp starts with a 1
That was related to 1970 (January 1) Excel is not supporting me a number for 1601 where this new timestamp is related to.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-convert-SQL...
