This may be entirely user error but, when a new ortho view is created in a brand new drawing, the 'FRONT' view is 'redded' out & unavailable to be created. Does this mean the front view exists somewhere in my template & needs to be removed?? If so, how? Any other thoughts as to how to fix this?
Thanks!
Solved by martinTstewart_Adsk. Go to Solution.
It would appear that the template already has the placeholder for the Front View, yet no views exist in the drawing. Also, if I delete the Front View from the list in the Project Manager (as per first screen shot), the next time a Front View is generated it appears as a tiny white box in the lower left corner & cannot be edited.
Perhaps this visual aid will help:
Hi Dallas,
Yes, always a good idea to include some images. Thanks!
You should be able to make as many front views as you like. It’s just that they each need their own name – no duplicates (that’s what the red means)
I think you just need to click into the red box and give it a unique name, like “Front View 1”
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Thanks for the tip about changing the name of the view, I had no idea field could be edited there. That helps.
However, it still doesn't explain why it is red in the first place - how can I remove the Front View (and apparently the Left View) from being pre-populated in the drawing in the first place (as per my first screenshot)?
