P&ID standards
P&ID standards
P&ID standards
Hi guys,If I'm working in PID JIS-ISO some symbols are not available in same tool Platte but I find it in some other standards how can I access it.Instead of condenser should I use heat exchanger symbol  ?
DGRL
@Anonymous
You can add new symbols in the project setup under the P&ID tab
If this was of any help please kudo and/or Accept as Solution
Kind Regards
can you help with step by step or little bit brief,Thank you in advance.
DGRL
@Anonymous
When you open Plant 3D in project manager you can right click on a project that is loaded and then click "project setup"
From there navigate to the tab "P&ID DWG Setting" and then to "P&ID Class Definition"
Go to the Engineerin Items or Non Engineering Items and chose the class that you want to add a symbol to. (i.e Equipement -> Blowers --> Centrifugal Blower)
There you can remove / add symbols bt also edit or add to toolpallet.
Any question?
Please let us know
Kind Regards
