We're looking to migrate drawings from AutoCAD P&ID 2014 to Plant 3D 2024. Our drawings use custom symbols, pallets & tagging. I've tried copying a drawing into a new Plant 3D 2024 project - but it doesn't bring in the custom class definitions. Is it possible to bring these drawings into Plant 3D 2024 without having to redefine everything?
Solved by rh8mpo. Go to Solution.
Dear @rh8mpo ,
Technically this is possible, but you have already let 10 years go by to become active.
The first step is to migrate the 2014 project to a 2017.1 project
This would be the most difficult part.
Then from 2017.1 to 2018-2024 as the projects are upwards and downwards compatible between P3D 2018 and 2024.
Good luck with that.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank-you for your response. Unfortunately, we have no control over the software we use - as a company we have moved to ePlan, but we have a large on-going project on AutoCAD P&ID that we need to transfer to a newer version.
Fortunately, we have discovered that the transition is straight forward - opening the whole 2014 project in 2024 migrates all of the settings and definitions. We can then import the old pallets and we're good to go.
