Hello everyone,
I have some problem using this P&ID Line List when opening the icon. It seems that all our P&ID line numbers are gone wherein we've created the P&IDs in Plant 3D so that when choosing the line number in this window, click the "PLACE" button and start the pipe modelling.
Can anyone tell me what happen why the link just disconnected, if I'm right with my findings.
Appreciate much your help.
Thanks you.
Hello @JoseFlorante_Sese
I recommend you on your project :
1 - Empty the Plant 3D cache by launching "PnPLocalDataCachePurger.exe", file placed in the folder "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D"
2 - Run the "AuditProject" command from the data manager without opening a drawing
3 - Open the 3D file
== French ==
Je vous préconise sur votre projet de :
1 - Vider la mémoire cache de Plant 3D en lançant "PnPLocalDataCachePurger.exe", fichier placé dans le dossier "C:\Program Files\Autodesk\AutoCAD 202x\PLNT3D"
2 - Lancer la commande "AuditProject" depuis le gestionnaire de données et ce sans ouvrir de dessin
3 - Ouvrez le fichier 3D
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Error for me !
Audit Project is in the project manager.
Cordialement
Dominique VAQUAND
www.dovaq.fr
See topic
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/19aNehY6lYm0wHEP3uZufr.html
maybe
Cordialement
Dominique VAQUAND
www.dovaq.fr
For the Pipeline Group:
For the Pipe Line Segments:
Thanks for your reply
That is one of the actual numbers in out P&IDs developed in Plant 3D. I just don't know what happen and suddenly all the line numbers were not anymore or not listed anymore in P&ID Line List when I clicked on the icon, the window is blank.
Still can't understand what you are trying to emphasize.
What number is missing in my Pipe Line Group Tag Format under P&ID Class Definition?
Here are the meanings of each parameter:
MPL-Main Parts List or Area
Fluid Code or Service
PLN-Pipe Line Number or sequence number
Spec-pipe spec
These are the only four parameters I've set in our project.
Thanks.
I have that also in my set up
One of my colleague created a copy of the same project and probably on that instance the link from the P&ID that was created in Plant 3D to the piping modelling somewhat disconnected or lost.
Anyway, thanks for giving some solutions. If you still have some idea to share with, will be gladly appreciated.
