AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Orthographic view blank and not creating layers from 3D model
6 REPLIES 6
lshadrick
377 Views, 6 Replies
I have my orthographic layer set up to "use 3D model layers".  However, when I generate an orthographic view, the viewport is blank and none of the 3D model layers are created in the orthographic view.  I have de-selected the option to use 3D model layers, and there is no change.  When I edit the orthographic view, the 3D model is visible, and I can set the ortho cube so everything should be visible on my paper.  Any suggestions for where to look next would be much appreciated.
6 REPLIES 6
h_eger
in reply to: lshadrick
Dear @lshadrick ,
Are there any 3D CAD objects in your Plant 3D models that come from external systems, e.g. STEP files?
Which Plant 3D version are you using?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
lshadrick
in reply to: h_eger
Hi @h_eger,
I am using Plant 3D 2023.  I do have a few imported solids.  I have a skid imported via parasolid from Solidworks.  And I have a large vendor system imported via .stp from Inventor.
h_eger
I would hide all externally imported models once and test the ortho creation and show the external models step by step until you find out where the problem is coming from.
Hartmut Eger
Senior Engineer
XING | LinkedIn
lshadrick
in reply to: h_eger
@h_eger, thanks for that idea.  I've been working through the imported models and the problem appears to be in a 3D DWG file that was imported from a vendor.  Is there a way to "fix" that model so it will work with the orthographic view?
h_eger
Dear @lshadrick ,
Troubleshooting a broken 3D model is something for the professionals.
I use CADDoctor for that.
Hartmut Eger
Senior Engineer
XING | LinkedIn
lshadrick
@h_eger, thanks for all of your help.  I'll try to go get a better export from the vendor first and see if I can get it working that way.
