Hello!
When I create an ortho view and move it I got a graphical bug - shadow.
See the upper left part:
This should be a normal top view.
Any help would be appriciated.
Thanks in advance!
Solved by jabowabo. Go to Solution.
Try toggling Hardware Acceleration on/off and run again.
Thats more of a diagnostic process than a solution. What it indicates is a problem with your graphics system, most likely a problem with the driver software. It may be out of date, a newer unsupported version which should be rolled back, or just incompatible with this version of AutoCAD products.
I have an Nvidia Quadro K2200 with the latest driver.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
