ORTHO dimesion lines with broken legs. refer attached image.
rvetalM4T2D
Message 1 of 8
rvetalM4T2D
Is there any way to create dimension style as attached in image.
Replies (7)
Message 2 of 8
DVaquand
Hello
To my knowledge in manual mode NO or by programming perhaps.
== French ==
A ma connaissance en mode manuel NON ou alors par de la programmation peut-être.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 3 of 8
Michiel.Valcke
So you want arrows for the first dimension and dots for the continuous dimensions?
The easiest way would be to make two dimension styles, and place the arrows-style default and then afterwards modify the style of the other dimensions so they will update to dots - or vice versa.
Message 4 of 8
rvetalM4T2D
I see, thanks. But that is not what I am looking for. I want dimension style with broken legs as attached in image.
Message 5 of 8
Michiel.Valcke
ah, I'm afraid that is not possible.
Message 6 of 8
lauri_barnhart
Hello, @rvetalM4T2D,
Did the information provided by @DVaquand or @Michiel.Valcke help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
Message 7 of 8
rvetalM4T2D
Hello, Thanks for the responses everyone.
In my opinion a dynamic block mimmicking the dimension will be a good solution to this.
I'm no expert in creating that, may I get some help to create such a dynamic block.
Message 8 of 8
Michiel.Valcke
You can try the block in this sample drawing as an example to start from - from there you can recreate according to your needs. There are some limitations towards the number of items you can dimension this way (you would need to create separate blocks or visibility states to add more dimensions) and I used fields in attributes for the actual dimension so you need to use the REGEN command to show the actual value. There is also no smart behaviour for the text placements so you have to do the text placements manually.
The people over in the dynamic blocks forum might be able to help you further:
https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/dynamic-blocks-forum-en
