I am running a BOM with cut list, so the pipe lengths are listed as seperate items but I have 2 components(blind flange, Blind flange with tap) with different descriptions (size and Family) and the BOm has them grouped together. So what I would like to do is group the items with the same descriptions together but if the description is different then a new row will be created. I attached a screen shot to show what the current BOM is creating.
Solved by eadkins73. Go to Solution.
Hi pstephany,
If you add a different material code to the blind flanges they will be placed on different rows of your BOM.
Tom (dadspackard/packin31)
Thanks for the reply, I tried adding differnet material codes and it still combines both the blind flanges.
