AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho Annotation Elevation Tag
9 REPLIES 9
Message 1 of 10
4840 Views, 9 Replies
I am using PLANT 3D 2014. As per my project requirement " All dimensions are in mm and Elevation are in mtr". During Ortho Annotation B.O.P Elevation Tag is showing in mm Units but I want to represent it in mtr Units in orthographic drawings.
9 REPLIES 9
Message 2 of 10
quentin.contreras
What you should be able to do is use the PLANTDEFINECALPROPERTIES command and do some editting of the project setup.
I have recorded a video that shows how to do this.
https://chronicle.autodesk.com/Main/Details/991e51c8-2a32-40a4-a079-bec22bebb300
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 3 of 10
in reply to: quentin.contreras
Thank you sir for this video. Ortho annotation tag for BOP in mtr is coming properly. but is it possible to indicate upto three decimal value ie, BOP EL 12.570 M
Message 4 of 10
dennis
With an INCHES to decimal FEET, using the same process, I get nothing.  And as well, I would like to limit the decimal percision.  Any suggestions?
Message 5 of 10
in reply to: dennis
I am still searching that solulion.
Have a look at this link, that may help you. But the problem is not solved.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D-General/Annotation-on-Ortho-drgs-ie-add-pipe-elevatio...
Message 6 of 10
viet_protocad
in reply to: dennis
Among other issues, i've just been tagging the elevations as decimal inches and leaving it as a non-plotting layer.
Then I'd get that number, run it through a lisp with the command "(RTOS 12345.32 4 3)"
RTOS being the native autocad command to convert, 4 being arch units, and 3 being 1/8" precision.
here are some resources.
hope this helps!
cheers,
viet
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-D03ABBC2-939A-44DB-8C93-FC63B64DE4A2
Message 7 of 10
Hello, can you show how to add a specific values to x and y coordinates, so that when I annotate the position, it would show new coordinates with added values?
Message 8 of 10
The link is broken. Can you help me to find the updated link please?
Message 9 of 10
Hello, the video is missing, please, could you send it or upload it again. I need to be able to annotate in meters the COP in my projects and I don't know how to do it. Thank you. best regards
Message 10 of 10
