AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Orbit uses WCS when in custom UCS
4 REPLIES 4
Garrett.Brothers
619 Views, 4 Replies
When using a custom UCS, fixed orbit still uses the WCS.  The fixed orbit command prevents the WCS's Z axis from twisting to either side.  This isn't an issue when the UCS and the WCS have parallel Z axes, but in a more unusual setup navigating the model becomes difficult.  This is an example where 3DORBIT ignores the new UCS in favor of the WCS.
I'm a beginner at Plant 3D.  It's quite possible 3DORBIT uses the WCS because that's what we want 99% of the time, even in a custom UCS.  However, if I needed to work in an angled space, constantly fighting with 3DORBIT might dissuade me from using a custom UCS in the first place.
Can anyone speak to this?
Labels (1)
  • ucs
4 REPLIES 4
Try setting the Autocad variable ORBITAUTOTARGET to 0
George
If my post offers a solution, please click "Accept as Solution"
Thank you for the suggestion!  Unfortunately, that didn't work.  OrbitAutoTarget determines whether orbit uses the center of the screen [set to 1] or the object you were hovering over [set to 0] as the orbit center.  It's a useful setting, but I'm looking for something that changes fixed orbit so that it uses the UCS instead of the WCS.
When you initiate fixed orbit, if the WCS's Z-axis is not currently straight up and down on the screen, it snaps the model around so that it is (the attached screencast demonstrates this).  The solution I hope to find makes fixed orbit use the UCS's Z-axis instead.
Edit: screencast link
h_eger
in reply to: Garrett.Brothers
this function is only fully integrated from Plant 3D 2021 🙄
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Garrett.Brothers
in reply to: h_eger
Thank you.  While it's sad that it's in Plant 2021, knowing that this particular setting will exist means I can stop searching for it.
Technology Administrators
AutoCAD Beta
