Open "Modify Equipment" dialog box in AutoCAD Plant3D via Plant3D .NET SDK programmatically
vaishnavi_agrawalSJ2Y6
I want to open the dialog box "Modify Equipment" which is shown when we right click on any Equipment in AutoCAD Plant3D drawing and choose "Modify Equipment" option. I want to do it programmatically using Plant3D .NET SDK. Is there any API or any other way to do it?
Similarly, I want to open "Add Nozzle" dialog box as well which is available on right click options of Equipment via .NET SDK.
Let me know if it is possible and how that can be done.
Thanks!
DVaquand
Hello
Without going through programming, you can activate the double click on a piece of equipment, to launch the “PLANTEQUIPMENTMODIFY” command, by only configuring the CUI menu.
(view in My Videos)
== French ==
Sans passer par de la programmation vous pouvez activer le double clic sur un equipement, pour lancer la commande "PLANTEQUIPMENTMODIFY", en paramétrant seulement le menu CUI.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
I am working on some functionality and as a part of that I want to achieve this via code only, without any additional user action or invoking any command separately. I want to open the modify equipment dialog box in one of the steps of my functionality.
