One Ortho Drawings have disappered from the project browser
CxIriartex
CxIriartex
Only one specific ortho Drawing have disappered from the project browser , it does not let me reintegrate it. I already did purge, audit, tried to re-establish the files ortho.dcf, Metric_OrthoPart.xml and Project.xml and nothing. The file is not being occupied by any other process obviously. Appears the next message: Not all FIles could be added to project. I cant find the error.
Dan.Scales
Hi @CxIriartex,
Try clearing the local data cache and retesting:
Plant 3D: Strange issues for some when using the same network project
Dan
Dan Scales
CxIriartex
I cleaned the data cache and it did not work, I still have the same problem.
jabowabo
Try making a copy of the drawing and adding it to a different project. If successful, copy that file and try to add it to your original project. Note: This is not likely to work but I have had success doing it with a similar problem.
CxIriartex
Neither can be added to another project, the same message comes out ...
Dan.Scales
Hi @CxIriartex,
The next thing to try is to recreate the ortho using a different name.
Dan
Dan Scales
CxIriartex
I have tried absolutely everything. I can not solve the problem ... Now another ortho and the model disappeared .. I can reintegrate the model by making a new one and inserting the original as a block and exploiting it. The orthos can not.
