On Inserting Socket weld flange in pipe a Weld neck flange on other end gets connected Automatically.
uk96710
uk96710
Hello Forum Experts,
Hope you all are doing well.
I am facing a problem as, On Inserting Socket-weld flange in pipe a Weld-neck flange on other end gets connected Automatically.
I have done all the necessary settings on Compound joints and simple joints also set the Priority in spec editor but didn't resolve the issue.
Yes OfCourse I can use size limits for socket-weld 1/2 "- 2" and above 2" weld-neck flange in spec editor while adding flanges but I also need Weld neck flanges in between size limits of 1/2" and above at some places.
Is there any method/settings I need to do.
Please let me know if there is anything you can help.
Umarfarukh Sabkhan
h_eger
@uk96710 ,
This change in the Connection Manager should solve your problem
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
uk96710
Hi @h_eger ,
Thanks For replying, it resolved the issue.
Umarfarukh Sabkhan
uk96710
Hi @h_eger ,
Adding Short description property resolved the issue however when I tried to insert Valves it appears connection issue.
Please let me know if you have any solution for that.
Umarfarukh Sabkhan
h_eger
@uk96710 ,
OK the task is to find a parameter that is unique between SW flange and flanged valve.
Hartmut Eger
Senior Engineer
XING | LinkedIn
