AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
OLETs - Not working - Not Connecting to PIPE
7 REPLIES 7
Message 1 of 8
1220 Views, 7 Replies
Hi all,
So I have exhausted all spec Olets, upon Placing it is added to the Drawing, but the olet doesn't connect to the pipe.
I have the water droplet on bot connection.
thoughts?
7 REPLIES 7
Message 2 of 8
Tomislav.Golubovic
What does the branch table in your spec look like?
Message 3 of 8
in reply to: Tomislav.Golubovic
The Branch Table -- was blank -- but edited it to include the appropriate size and OLETS
and still having this issue..
Message 4 of 8
Make sure you check the required property matches in the joint settings in
project setup. Could be material, class (150, 300) conflict... also make
sure you have the sizes active you need within the spec.
Message 5 of 8
What and where exactly?
Message 6 of 8
timothy.bourque
I have found that olets only work correctly when added from the spec viewer and they do not work correctly when added from the tool pallet
Message 7 of 8
ben.saa
in reply to: timothy.bourque
Check the connection settings for Tap
Message 8 of 8
km4504
Are your end types properly designated?
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
Technology Administrators
AutoCAD Beta
