Olet port 2 size only in Iso BOM?
Message 1 of 15
Is there a way to only show the size of port 2 for olets in the BOM on isos?
I want this to happen to olets only. My concern is that if there's a way to even do this, I don't want it to affect things like reducers too where you do want to see both sizes.
Replies (14)
Message 2 of 15
h_eger
Dear @Anonymous,
can you show an example how it should look?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 15
In the picture I attached to the original post, the couplings that are being used as olets should just be 1" and 3/4". There's no such thing as a 6"X1" or 6"X3/4" coupling. They aren't reducing couplings. It's just a 1" or 3/4" coupling on a 6" line.
Message 4 of 15
If you want to have a specific description in the BOM you can add a column for the "Short Description" in project setup in your TitleBlock setup. Then you can edit the Column in the spec that is labeled "Short Description" and put your coupling call out in there or in what ever column you choose. I have used the Short Description in custom spec to be just generic callout. for example, for Sockolet it would just read "2 SOL", or whatever you want it to name it.
Message 5 of 15
I think I'm good with the descriptions that are being used, I just don't want it to display the "Header" size(port 1) in the ND column on branch connection components. Can't I just turn it off somehow?
Message 6 of 15
The only resolve that I have done so far is to that would be to edit the isoconfig.xml file for the isostyle you are using. Using a custom column in BOM for size is another option, just have to pick one that is editable.
Anybody else want to chime in?
Message 7 of 15
What would I need to edit in the Isoconfig.xml?
Message 8 of 15
After doing some digging, I could not edit the BOM in the isoconfig.xml file. I will do some further research.
Message 9 of 15
Ruffy85
it´s not possible to show other port sizes in the BOM like the Size Column.
you can define new properties, but it doesnt exisits a property which shows that value what you want. And the predefined and avaiable functions are to restricted to do that what you want.
The only way what i see is with lisp function or similar third party extension.
after creation run a lisp function which searches in your table for the row OLETS, then iterate trough all rows till the next header and compare the column 3 cell value with a list and replace the value in that cell with the new one, or use string methods to get the final result what you want.
But quick there is no on/off button to do this.
Message 10 of 15
I have modified specs and put data in editable columns, then add the column to the BOM Table Setup and it will show. For instance, Item Code column in spec, put the size there. Add this column to your BOM and rename it size in the template. No lisp routine needed.You just need to know how to edit your specs and should be good. Multiple specs can take longer to edit. And a lot easier than writing a lisp for this type of option.
Message 11 of 15
Ruffy85
yep, but size is not "showing only port2 size"
the possibility to add custom colums to isotablesetup i know...
Message 12 of 15
ryan.bales
Autodesk Support
Autodesk Support
This came up a while back and was recommended to post to the idea station: Properties for second (or more) port in ISOs in BOMs
Basically that info is in the port data and the BOM's don't link to that property. I imagine it "could" work if you created a property identical to a port property but there would nothing to tell that property to acquire that data.
Ryan Bales
Fusion 360 Product Support
Message 13 of 15
I'm not looking to ADD properties. I just don't want to see the size of Port 1 for Olets on the BOM. Since a 1" coupling will be purchased I don't need/want to see 6"X1". It's just 1"...
Message 14 of 15
ryan.bales
Autodesk Support
Autodesk Support
I understand what you want to do. But with Olet or coupling/reducing fittings you are trying to add properties that can be displayed in the BOM but do not exist anywhere accessible by the BOM Table currently - mainly port properties.
Because it's looking at "SIZE" which is a combination of PORT 1 and PORT 2, as defined in the catalog, you can't simply say "look at port 1 or port 2". For parts of the same size that second port is dropped.
Ryan Bales
Message 15 of 15
Ruffy85
Absolutly true
