AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
NWCOUT not working in Plant3d 2025
1 REPLY 1
santoshbaraiya
95 Views, 1 Reply
I have installed plant3d 2025 version and also installed Navisworks Exporters Utility 2025.
The issue is I am not able to export my model into NWC file using NWCOUT command
My Plant3d is not recognizing NWCOUT command
1 REPLY 1
😞 works for me, best file a bug report with Autodesk directly through their support.
In the mean time you can just append the dwg from Navisworks, a nwc file will be created by default.
Technology Administrators
