North Arrow on isogen
Does anyone know how to turn off the North arrow pointer in the isometrics? what file and switch number it is in so that I can turn it off.
thanks
Jose
bogdanov.y
Project stup->Plant 2D DWG Settings-> Isogen Settings-> Configure title block-> Select your "Iso type" and enter in "Setup Title Block"
In the block editor enter in "Drawing area setup" (the second icon) if you don't see it you can use the command: _ISOGENTBDRAWINGAREASETUP
 In this window disable "Show default arrow symbol"
thanks Bogdanov that will fix it.
I have also found since that it is switch tag no -700 in the XXX.alt file in the isogen dir needs to be set to 0 0 0
Jose
