No connection defined for end types FL and SW in the config file
shadow931
shadow931
What causes this error, it came out of nowhere, also what means FL and SW ? It happens when I try to place a flange on a pipe, before the program was doing it automatically now this error comes up.
ramabalanv
@shadow931,
Error is because of the pipe length, which is not enough to create a mating flange(Auto-flange connection). Try extending the length of the pipe and  re insert the flange.
shadow931
Thank you for the answer but the pipe has a considerable length, it's more than 1 meter.
ramabalanv
Does this mean the problem still exists? or Solved?
If problem still persists, Please remove the solution
shadow931
It got fixed, thank you.
PauloJoaquin
Community Visitor
Community Visitor
hi, I have the same issue. how did you resolved it?
