Hi
Using P3D, 2016 SP2.
Can not enter negative number for offset. We were able to do this in P3D 2015, no problem.
We are trying to enter this at the "project settings:Isometric DWG Settings" dialog box.
According to the 2016 help, it will accept negative number:
"Override Location Offset location Adds X and Y values to objects in the isometric drawing. You can enter negative values (for example: -10000). Offset rotation Rotates objects in the isometric drawing. You can enter negative values (for example: -90). Offset rotation is calculated before offset location."
Doesn't work for us.
The error we get can be seen on the attachment.
Same error is presented whenever we try to enter negative value at the "iso creation....advanced options" dialog box.
What's wrong?
Solved by fatherof3. Go to Solution.
My colleague discovered a work-around:
Edit the "isoconfig.xml" file for each iso template.
ExportFormat="0" OffsetLocationX="-35930" OffsetLocationY="11487" OffsetRotation="0" RevisionNumber="" IssueDWGs="false"
