Need help with Grooved pipe
abdelhalim_bousmaha
abdelhalim_bousmaha
I have to connect the flange (it's a custom part ,  red color ) to the pipe with a Clamp but Plant does not accept the connection, because in one side I have DIN and in the other ANSI pipe class as you can see in the picture.
is there a way to connect the two elements?
Thank you 🙂
h_eger
Dear @abdelhalim_bousmaha,
The connection of flange S2 is PressureClass 16 which must be 150 so your clamp can be set.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Look for the specific joints and check the "Imperial to Metric connection"
Regards
Bernd
Bernd G.
Senior Product Support Specialist
