AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
MULTI USER SQL SERVER DATABASE
2 REPLIES 2
yogesh_sankpal3WAHJ
174 Views, 2 Replies
IF I AM CREATING NEW PROJECT ON SERVER WHICH OPTION I SELECT & HOW IT WILL WORK?
2 REPLIES 2
Do you have an SQL server for your plant 3d Projects? If not, then you have to use Local SQLite.
If you have, then you type in servername and a unique name prefix since it's a new project - as you can see you can test if name is acceptable, it will return error if name is already present in the database.
If you are unaware of the servername etc. then contact your IT.
Authentication either with Windows account or specific credentials (your IT will know).
Read the built-in documentation: https://help.autodesk.com/view/PLNT3D/2024/ENU/?guid=GUID-5D9CE5B5-0FD8-45D9-8D5B-B7F7F62C07A6
DarrenP
