Multi-Port Valves with custom Actuator
wayne_deegan
Message 1 of 14
wayne_deegan
I am trying to setup Multiport valves with a custom .dwg block based actuator, it works for the default port orientation but when you change the port orientation the actuator moves in the z axis for some orientations and jumps to the end ports for others?
A1=180, A2=0A1=180, A2=90A1=0, A2=0
Replies (13)
Message 2 of 14
Ruffy85
Hi @wayne_deegan
How is your Actuator configured?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 3 of 14
wayne_deegan
Hi Ruffy85,
The Actuator is a "Custom - AutoCAD DWG based graphics" part created using plantpartconvert, the actuator shown is just an example, the actuator I want to use is much more complex so the use of parametric graphics is not an option. The Actuator is mapped to the valve body using "Edit Operator Assignments" in catalog editor.
Wayne
Message 4 of 14
Dan.Scales
Hi @wayne_deegan,
Did you draw the actuator block vertically on the Z axis?
If so, try drawing it along the Y axis and retest.
Dan
Dan Scales
Message 5 of 14
wayne_deegan
Hi Dan,
Actuator is drawn on the Y axis, appreciate the effort though.
Wayne
Message 6 of 14
Dan.Scales
hI @wayne_deegan,
I can't reproduce the problem here.
Is it just the actuator that is block based?
Dan
Dan Scales
Message 7 of 14
wayne_deegan
Hi Dan,
Yes, it is just the Actuator that is block based, the housing is a plant 3D parametric graphic valve body.
Wayne.
Message 8 of 14
wayne_deegan
Hi Dan,
Catalog and spec attached.
Wayne
Message 9 of 14
Dan.Scales
Hi @wayne_deegan,
I have reproduced the issue with the block based actuator on multiport valves and will get it logged with our development team.
Unfortunately for now all I can suggest is to use a parametric actuator.
Dan
Dan Scales
Message 10 of 14
wayne_deegan
Thanks Dan,
Appreciate the time you have put in.
Wayne
Message 11 of 14
WWBierma
So is this already fixed?
I have the same issue in Plant 3D 2020.
Message 12 of 14
rajendra.prajapat
@WWBierma @wayne_deegan
This problem can be fixed by editing the multiport valves autodsk python scripts.
Message 13 of 14
eystein.killiVM42H
Hello Wayne. Can you be a bit more specific what to change in the python script?
Message 14 of 14
rajendra.prajapat
@eystein.killiVM42H you can quick fix by valves properties.
just add 0.0000000001 in your angle value like 90 + 0.0000000001=90.0000000001 . use this value as angle.
