Modify pipe spec viewer
milic.srdjan
milic.srdjan
Halo to all,
Is it possible to modify pipe spec viewer, plant 2018, this tool we get with
Command: PLANTSPECVIEWER
to have more columns, then default. Now we have only
Min Size to Max Size     Long Description
and I wish to have more columns, like Item code, etc.
Many thanks in advance,
Srdja
h_eger
Dear @milic.srdjan,
unfortunately, there is no way to customize the SpecViewer on your own wishes.
This setting is HardCoded
The SpecViewer is just a window in the SpecEditor
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Ruffy85
Only trough the API, there you can display the Spec Entities in a Tool palette and show the columns you want.
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Dear Srdjan,
as Hartmut already said, it is not possible to add a column in the Spec Viewer but there is an alternative. Just edit the long description style (family) and add there the item code. Then it is listed also in the Spec Viewer in Plant 3D. I have create a video with audio for you.
Hope this helps.
Regards
Bernd G.
Senior Product Support Specialist
darrelldixon
This would be a feature to ask for on the Plant 3D Idea Station:
https://forums.autodesk.com/t5/autocad-plant-3d-p-id-ideas/idb-p/48/tab/most-recent
matthieu.macq
Is this Plant 3D idea has been implemented or is there now an option to customize the pipe spec viewer in order to add additional properties/column in it?
Thanks for the update.
jabowabo
There is no change to how this works in 2023.
