Modelling fixed pipe minium length not getting in model. Specs. Likes(HDPE,MSPTEF,PTFE,MSTL).
nilesh.shirsath
nilesh.shirsath
While creating Pipe spec. minimum length for fixed pipe is not getting  incorporated in model, even specifying    minimum length in pipe spec.
also it is not shown in part properties in spec editor and in 3D model.
AndyDavisArkance
The existing specs that ship with Plant 3D in the CPak AME folder have an older data structure that does not include the Minimum Cut Length pipe property.
You will need to create a new spec to fix this, I'm afraid, and add the pipe from the catalog. Do not use Create Spec from Existing... as it will simply duplicate the out of date spec and not add the missing property.
I hope this helps.
Andy
Andy Davis
Industry Specialist
ARKANCE
nilesh.shirsath
Thanks Andy. It will work and getting as per our requirements.
