AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
misc-component tags missing from p3d iso
2 REPLIES 2
MOLGRAND
353 Views, 2 Replies
A simple one i think, but i am struggling to find the answer - i want the misc-component tags to appear on the ISO output drg. Currently I am working with plant 3d 2022 & just need a pointer to see the xml file line to modify. A couple of screen shots would be good. Previously i did cheat by assigning them as valve, instrument etc to get them to show tags when needed on an Iso as a simple fix.
I may also want to show the misc-components in a separate section on the ISO bom as well - so again a little pointer would be helpful.
Many Thanks
Gary Randall
2 REPLIES 2
George.Endrulat
in reply to: MOLGRAND
There's plenty of tutorial on adding instruments to the iso bom, misc-component works the same, same steps just slightly different verbiage.
George
If my post offers a solution, please click "Accept as Solution"
vijay.trivedi
Hello @MOLGRAND ,
Here is the example of Spectacle Blind (Misc. Component). You can applied this to your other Misc. Types of pipe fittings on your project set-up.
For ease I would like to share screenshots for same.
(i) Assign Properties for Tag and Tag format
(ii) Now assign Tag to Misc. Part by right clicking on it and go to Properties tab
(iii) Add Component Scheme for same
(iv)Now generate Isometric
With regards,
Vijay Trivedi
