08:38 AM
When I try to insert a Lug type butterfly valve I get the error attached. I'm running the pipe then dropping the valve in the middle of it. I get the error along with no flanges or gaskets. If I start with a flange then add the valve, mating flange, then the pipe on both ends I don't get any errors and the gaskets come in. Why would it think I'm trying to connect LUG to PPL anyhow? Wouldn't it assume that a LUG end type would need a FL end type against it? I'm on Plant3D 2014 by the way....
