We are using Autocad Plant 3D 2021 and we would like to list all stub-in connections in a format like
Line Name- Piping Class - Header Size -Branch Size
Eg: CWR17-AA21-10"-4"
By this way we would like to check all stubin connection from the list and revise some of them as Reinforcing Pad.
The data manager only gives me an idea about the branch size but does not include header size.
You can see the screenshot of the datamanager table.We also need the header size. How can we manage to extract this list?
I don't know of any way to get the connection data of the stub-in in the list.
Neither in the DataManager nor in the ReportCreator.
Programming is probably necessary for this.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@Anonymous
Hi
I understand your idea.
It is good to have such a list, but I do not understand
you have said "I need Stub-In..." but in P3D Data Manager, you have selected Buttweld p3DConnector.
In my project Stub-In = Tapweld P3dConnector
Picture below.
in addition, you have also marked field Design Std, as Diameter2, but Buttweld can have only one diameter, and it is wrong field.
So, if you try to think in a "way of Tapweld P3dConnectors", than you will have more options,
and you will be able to define new properties for that.
Best regards,
Srdjan
