AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
List of skey's
2 REPLIES 2
aquaphil
22798 Views, 2 Replies
List of skey's
The standard specs don't have reducing bushings so I'm attempting to add one into the catalog. I'm starting with a reducing insert but I'm not sure what skey to assign. Is there a file or document available that describes what the various "skey's" are?
2 REPLIES 2
jabowabo
in reply to: aquaphil
<project folder>\Isometric\IsoSkeyAcadBlockMap.xml
Your skeys can be whatever you want to map in this file - Plant 3D doesn't really care. If you are using the .pcf files in Caesar, Spoolgen, or some other app, you may want to be careful to stick with their skey names.
Note: 'Content Iso Symbol Definition' Types are pre-defined.
Dadspackard
@aquaphil ,
Attached PDF has a good list of default SKEY symbols and the corresponding block it uses.
Hope this helps.
Tom
aka, Dadspackard, Packin31
