lined pipe annotation/numbering issues for fittings
ahmad.alnatour
ahmad.alnatour
hello every one,
I use Resistoflex Content pack for lined pipe modeling/isometric.
Issue: when generate isometric Some items are not numbered and do not appear in BOM for example the instrument tee
attachment : isometric with BOM screen shoot, PCF file( compressed )
any idea to solve it
@h_eger @Tomislav.Golubovic @rajendra.prajapat @George.Endrulat @Bernd.Gerstenberger
thanks
rajendra.prajapat
@ahmad.alnatour  Hi, i have checked Resistoflex catalog. in catalog they have metionend SKey as per bleow image.
you can slove this problem by two methods.
1. change the  skey as per below image.
2. Add the new group for Instruments  in the isoconfig.xml. to adding this please refer below link.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
h_eger
Dear @ahmad.alnatour ,
Please add the Instrument Section to your Isoconfig as described in the link.
Your problem is solved.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ahmad.alnatour
@h_eger
@rajendra.prajapat
THANK YOU
i just change the ISO SYMBOL TYPE to TEE and keep the ITFL as ISO SYMBOL SKEY
this put the instrument tee under fitting section not instrument section and keep the block symbol as instrument tee
and for sure annotating/numbered on isometric drawing.
thank you all
