AutoCAD Plant 3D Forum
Line number tag doesn't show when no object assigned.
2 REPLIES 2
quan_hm
180 Views, 2 Replies
Hi all,
I have an issue that when I create a new line number tag and start routing everything is fine
but when I delete all the item relate to that line to create again then the line number tag disappear. It seem to only show up when at least 1 object assinged to a line number tag.
My ultimate purpose is to create an empty line number tag ready for user start to work so without any item assign to that line number but still can be selected from the dropdown menu. How to solve this?
Thank you.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
2 REPLIES 2
h_eger
in reply to: quan_hm
Dear @quan_hm ,
The line number is not saved if you delete all objects of this line number.
This is the way Autodesk has programmed it and it is fine otherwise there would be too many line numbers lying around in the project that would have no use.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
quan_hm
Thank you.
Technology Administrators
AutoCAD Beta
