LINE NO IN NAME PLATE
kumarswapan64
kumarswapan64
How can I bring the Complete Line No. in the Isometric Drawing Name Plate.
Please see the attached files.
Swapan Kumar
VinodBalasubramanian
Autodesk Support
Autodesk Support
Hi Kumar,
I think Darrell has provided all the necessary links to get this working. Please let us know if you need more information.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
kumarswapan64
Sorry. I could not Bring the complete Line No (Size-Spec-Service-Number) in the Name Plate.
See the attached file.
Swapan Kumar
kumarswapan64
Darrel,
Thanks for your reply.
But I could not bring the Complete Line No. (Size-Spec-Service-Number) in Title block. See the attached file (4.png).
One more in your 1st link "De-Mystifying__" is not matching with my Autocad Plant 3D. See the attached Sketches.
I will be glad if you can sequential snapshot (5 & 6.png)
Swapan Kumar
darrelldixon
The picture (5.png) from "demystifying" shows a new property that was created called "LineGroupNumber". Then they changed the ISO title block template to show "LineGroupNumber" instead of "linenumber".
What we have done is created a new Tag Format for the P3d Line Group tag. I also called it Line Group Number and made it 4 sub-parts (Nominal Size, Service, Number, Nominal Spec) and set that new one as the current TagFormatName. I am then able to use that new Tag to both annotate my orthos and to show the format I want in my ISO title block.
