AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Line Gap Not Generating
0 REPLIES 0
Message 1 of 1
jeff_evans2JWY6
136 Views, 0 Replies
I'm having a persistent issue of line gap going away. If I draw the lines first and separately from the equipment, it generates correctly as seen in screen shot below
But if I were to draw the lines from the equipment or connect the lines to the equipment the gap goes away and I start to run into other anomalies in the line behavior.  Examples below:
After shifting the right vertical line, the horizontal line becomes segmented without a grip point and the line is no longer level.
I've also placed Inline Assets and the line behind is not blocked out.
I have started a new drawing and placed new cells/lines and seen this issue persist.
Additionally, I've been seeing a much higher incidence of ACAD Error codes causing the program to shut down and sending error report to AutoDesk.
0 REPLIES 0
