Line annotation background mask misaligned
h_vanderweerd_7T8R4YGM2LVZ
Hi all,
I have got the following problem. Unwanted gaps are appearing in lines that are close to a line annotation. This gap is really not close to the actual location of the text. The gap appears in the line if the annotation is placed later. Lines placed after the annotation don't show this gap.
The text is left justified (bottom left in fact), and uses a few properties of the target line.
Does anyone have an idea why this is happening?
Two examples:
h_vanderweerd_7T8R4YGM2LVZ_1-1719400263338.jpegh_vanderweerd_7T8R4YGM2LVZ_0-1719400256888.png
h_eger
@h_vanderweerd_7T8R4YGM2LVZ ,
to do this, you would have to check the annotation texts of your project in the project setup for a character that is not displayed or something similar that creates this gap from your pipe line TAGs
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hello @h_eger,
thank you for taking the time to respond!
I've double-checked, but there are no other attribute definitions present in the annotation:
(blacked out a part of the property name referring to the customer)
h_eger
Hello@h_vanderweerd_7T8R4YGM2LVZ ,
the only thing I can find is that the insertion point is different from the standard.
Hartmut Eger
Senior Engineer
XING | LinkedIn
