I wanted to create a left-handed UCS, however it seems that Plant 3D only accepts right-handed UCS. Or am I overlooking something?
I want X towards North, Y towards East, and Z upwards. However when X and Y are correct Z is downwards, and whatever I try to rotate or flip the whole thing it keeps the UCS a right-handed system.
Thank you for any help or confirmation this is not possible.
Solved by Michiel.Valcke. Go to Solution.
Solved by matt.worland. Go to Solution.
I don't believe this is possible
Hey Steven,
All AutoCAD based products use the right hand rule to determine the positive side of the Z-axis. It is not possible to create a left handed UCS
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
