- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have this issue where stub-end ISO orientation of LAP joint connections is shown in wrong direction when two flanges are connected directly one to another (Face to Face) - In this case one of the stub-ends is flipped in wrong direction.
However, when LAP joints are used to connect i.e. Valve on a pipe, ISO representation (orientation) of both stub-ends are correct.
Another example is when pipe is left opened on one end and have LJ on another, LJ orientation is not the same if pipe i.e. have LJ added on both of its ends (examp. 2,3,4 in ZIP file).
We are using Plant 3D 2017 with Update 1.1 but for us same issue appears also in Plant 3D 2018.
Can someone please give constructive explanation about what could be a problem and how to solve it.
Any help would be appreciated very much since we are not able to trace the source of this behaviour.
Attached ZIP file contains Plant 3D Test spec, Test defaultconnectors.xml and Test drawing with DWG and PDF examples of created isometrics.
