Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Jacketed piping (spec/catalog)
9 REPLIES 9
Message 1 of 10
766 Views, 9 Replies
Hi everyone,
Can anyone help me create a jacketed pipe spec/catalog for ASME.
I need some elbows,tees, pipe, valves... but i don't if it's possible to make a real catalogue.
Thank you very much
9 REPLIES 9
Message 2 of 10
Tomislav.Golubovic
If you have the paper catalog I'll do it, for a fee though.
Message 3 of 10
in reply to: Tomislav.Golubovic
What Paper catalog?
Thank you
Message 4 of 10
Tomislav.Golubovic
Apologies, its a term I use for if the Catalog you want created, from a vendor, or standard, or whatever, exists in Paper/PDF form, and it needs to be created as a (electronic) Plant3D Catalog.
Message 5 of 10
here is an example what type of pipes i want to do in mm.
For example: inside pipe (12.70mm) and outside pipe (25.40mm)
see the pic.
Message 6 of 10
Tomislav.Golubovic
Is it just the pipe and you're going to use the Fittings from other catalogs, or do you need the inline fittings to be in the Jacketed Pipe Catalog also?
Message 7 of 10
I need only pipes for now, maybe later elbows and valves.
Thank you very much
Message 8 of 10
Tomislav.Golubovic
Send me a DM with your email address and i'll get a quote to you.
Message 9 of 10
Sorry for my bad english? what is a DM?
my email is: nuno.soares@cinoxsa.ch
Message 10 of 10
Tomislav.Golubovic
Direct Message 🙂
No problem, I'll send you an email now.
