Issues creating Isometrics - Errors in Iso Creation Log File
Having some issues generating Isometrics from a drawing. Not sure what has happened. Take a look at the log file I have attached. I am hoping it is a simple setting I have accidently changed!
Any help is much appreciated.
Did you make any modifications to the iso.dwt file?
No changes made to the .dwt file
jabowabo
Check the IsoContentSymbolDefinition for the item in the drawing with port locations here:
ERROR   - Failed to create necessary acad entities for the component - ClassName = '': Name = , Point = (39615.7437971779,39307.4158229889,-39193.5342798332), Size = 0.00, Dir = (6.25,0,1.45519152283669E-11), End = ; Name = , Point = (39609.4937971779,39307.4158229889,-39193.5342798332), Size = 0.00, Dir = (-6.25,0,-1.45519152283669E-11), End =
FAILURE - eKeyNotFound
It looks like there is something about this item that is tripping the process up. Could be the skey or maybe something else. You could replace it with some pipe temporarily to verify it is the problem item.
Found the solution within the iso.dwt file path.
So it was the iso.dwt file, hmm.
