Issue in Pipe support
dharunkumar.am
dharunkumar.am
I found a weird bug today. In my piping model I added pipe supports of respective sizes . But when I change the size of the support in the properties menu it changes without showing any error like "cannot connect part" or something. Is it possible to correct this ?
(view in My Videos)
h_eger
Dear @dharunkumar.am ,
of course you can do this so only it has no sense!
The supports are dependent on the pipe diameter and the pipe diameter is changed also the support.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
dharunkumar.am
the question is why cant it show "cannot connect part" error when I change the support size.
h_eger
because this is the wrong way to work.
I am more convinced that the designers who work with Plant 3D learn how it works in a training course and thus this or similar cases do not occur at all, because if an error message should be output for every misbehavior of the user, working with Plant 3D would turn into an error message click away program for some users.
Hartmut Eger
Senior Engineer
XING | LinkedIn
George.Endrulat
I believe validate should pick this up, and that's why we run validate on every line prior to isoing.
George
If my post offers a solution, please click "Accept as Solution"
dharunkumar.am
I tried validate . It didn't detect it .
George.Endrulat
Then I wouldn't change the pipe support size there, I can't remember if I've ever changed the pipe support size like that, I just rely on the line diameter to determine that value.  In the python scripts for supports (custom or not) a lot of sizing cascades down from pipe diameter, so if you futz with that it's clearly not going to match what you've set in your catalog / spec for sizing for that line size.
George
