isometrics piping size over title block (coming outside of sheet)
yogesh_sankpal_pune
yogesh_sankpal_pune
After extracting Isometrics for the piping, I am facing a issue that my isometrics are extracted outside of title block like below images, scale of sheet and extracted piping is not matching.
Replies (13)
h_eger
@yogesh_sankpal_pune ,
I know this problem, in many cases it is due to faulty pipe components such as block-based pipe fittings or valves.
Do you have a log file for this iso in which you can also find the reason why the iso generation did not work?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
yogesh_sankpal_pune
dear Egar Sir,
thanks for reply  i check log file but there is no error fund in log file
check below please
Iso Creation start time : 05-08-2024 16:09:15
Iso Creation finish time: 05-08-2024 16:10:27
Duration : 00:01:11
1 Isometric(s) successfully created with no error conditions:
h_eger
have you ever tested what comes out of the iso when you set break points?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Tomislav.Golubovic
In the Title Block template did you set the Draw Area?
yogesh_sankpal_pune
yes set draw area & 1 pipeline generated total 5 sheet 4 sheet coming corrected but 1 sheet only coming out of sheet especially loop is there
Tomislav.Golubovic
If its a big loop, I had something similar but ended up breaking the line in two with a A and B at the end of the line number to break it up, then it worked.
yogesh_sankpal_pune
h_eger
Hartmut Eger
Senior Engineer
XING | LinkedIn
yogesh_sankpal_pune
Dear Egar sir,
thanks for reply ...but my requirement is wanting all loop in 1 single sheet that's the reason i fix break points there
h_eger
this was only intended to localize the problem. You have to find out which part of this loop is responsible for the fact that you cannot generate a complete iso.
Can you upload the PCF file of this loop?
Please change the file extension of the PCF file to *.txt otherwise it will not work with the upload
Hartmut Eger
Senior Engineer
XING | LinkedIn
yogesh_sankpal_pune
Dear sir i attached ZIP file of PCF format
h_eger
As a single isometry it works as long as I deactivate the sheet division I get exactly the result of the iso as described by you.
seems to be an error in the bypass function of Plant 3D. Please report this problem to Autodesk AutoCAD Plant 3D Support.
Hartmut Eger
Senior Engineer
XING | LinkedIn
yogesh_sankpal_pune
thanks for your kind supports i will check same with plant support
