Hi to everyone..
There are any possibility to divide the same "Cut Piece List" y Two little tables in Isometrics Drawings?
I tryed to insert into "Setup Title Block" two "Cut Piece List" in differents areas but it is generated with the same data.
I looking for two "Cut Piece Tables" with the all information of the Isometric generated but with the "Cut Piece Items" distributed in both tables, to use the minimum space on "Bill of Material"
So you're looking to split it into two columns to better fit it on the paper?
Yes, I´m looking for Split into two smaller tables with information distributed in both.
cut piece list
ID Lenght ND Comment l ID Lenght ND Comment
01 1125 300 l 05 750 200
03 980 300 l 06 200 100
04 100 300 l
l
l
