In autoPlant 3D 2012. I have edited the Isometric title block through the project properties. The tiltes attributes are mapped to the project and created to be centered. Everything looks good until you create the Iso's. The center justified text is not centered. see attached shots.
I recreated changes from scratch in new job and have same outcome? Any suggestions? Is this a known problem?
Thanks for any help.
This is a known issue that has been reported to our developers.
To workaround the issue you need to run the ATTSYNC command on the Isometric drawing.
Dan
Thanks, we're about to update to Plant 3D 2013, is it fixed?
Sorry for the misunderstanding, I am not quite familiar with the forum.
my answer is: no, not fix yet, and I am using 2014 ext1.
I trying to install EXT2, but untill now, i have an error message.
regards.
Even on version 2015 not fixed yet.
by the way, some errors on version 2014 doesn't fixed on version 2015.
I work the most on small piping under 3" with threaded connection and socket welded connection, and 3d plant Isogen has some errors when I pull out the Iso drawing. I was report to Autodesk, but the errors doesn't fixed yet on the version 2015, hopefully it'll come by 2016. Now I stuck with that.
RE: This Topic
Here is a band aid. Create a *.lsp file and copy this into it and then put it in your startup suite:
(defun FixTitleAttributes (/ ss e) (setq ss (ssget "_X" '((2 . "Title Block")))) (if (and (not(null ss)) (>= (sslength ss) 1)) (progn (setq e (ssname ss 0)) (command "ATTSYNC" "S" e "Y") ) ) (princ) ) (FixTitleAttributes)
Reposted: to use code block and fix a portion of code. This is a stripped down version of what I use; its not tested, but should work.
RE: The fact that this issue has been persistant over a large number of P3D releases
I am a recent user of Plant 3D and thus far am quite disturbed by the lack of development on the product. Again, so far I've seen nothing that instills hope for the future. I really wish PID/P3D were independantly developed. I feel very strongly that they have spread their resources way to thin on this package and it is proven by this ridiculous/persistant problem. If they want PID and P3D to talk then develop that "module" independantly! In the meantime give us a functional piping program!
If it wasn't for the fact that I have to use and battle with Plant3D every day, these issues that have not been resolved for several years over several full product releases, service packs and extensions would be quite laughable.
But as a user who has to battle with this lack of product development (or is it more a case of recognition and support for the end users?) it's not laughable, it's **** annoying. The only ones who are laughing are Autodesk's competitors.
When is the attribute alignment going to be fixed?
As I understand it this is an issue for other Autodesk products as well (eg. Civil 3D). However, the fact that the out of the box title blocks work perfectly makes me think that there is a way to fix this. I wish they would.
Can anyone from Autodesk repsond to this? The silence on this issue is concerning.
someone sent me a lisp that I have loaded on all machines that corrects the centering and it seems to be working
oops the lisp is shown below:
(defun FixTitleAttributes (/ ss e) (setq ss (ssget "_X" '((2 . "Title Block")))) (if (and (not(null ss)) (>= (sslength ss) 1))(progn (setq e (ssname ss 0)) (command "ATTSYNC" "S" e "Y") ) ) (princ) ) (FixTitleAttributes)
I saw these responses but this seems to be an ongoing issue that Autodesk is failing to fix. So I wanted to see what the official stance from an Autodesk representative was on this subject.
It's fixed in 2015 SP 1.
I don't know why my 3d plant premimium doesn't have the pop-up for the update.
I just download the SP1, this for AutoCAD 2015, but it said that can work on the 3d design plant. I tried but it doesn't fix. maybe because I import the project from 2014 and the template too. but it is weir, it should work, because just a template.
I should try from crash and see. any body out there try it from the crash?.
thanks,
