Isometric showing wrong elevation of pipe for stub-in
JamesHattersley83
JamesHattersley83
I have a pipe that is welded into an existing pipe at 45 degrees. The centre line elevation of the existing pipe is showing incorrectly and doesn't add with to the dimensions on the iso. The screenshots attached show the highlighted existing pipe cop as 2650mm but the isometric shows 2563mm. When you add the 423mm dimension to the el 2227mm is adds up to 2650mm but this isn't shown on the iso. Our piping contractor noticed this and wants it fixing so that it is correct.
Any ideas why this happens and how to show the actual pipe COP elevation? Is the 2563mm elevation the height at which the pipe is welded and not the COP?
h_eger
Dear @JamesHattersley83,
it works for me! (Plant 3D 2019)
With which Plant 3D version do you work?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
I will send you a separate email. Please, send me back the model drawing and the isoconfig.xml of the used iso style. I will look into this issue. What for a version do you use?
Best regards
Bernd G.
Senior Product Support Specialist
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Hello James,
thank you for sending me the files. This is caused because your connector is a Reinforcement Pad and the Center of Gravity of the Reinforcement Pad is 2563. This will be shown in the isometric drawing.
Hope this answers your question.
Best regards
Bernd G.
