AutoCAD Plant 3D Forum
isometric line number does not populate in attributes
2 REPLIES 2
hwood818
612 Views, 2 Replies
In Plant3d 2016, i am able to generate an iso, but none of the titleblock attributes fill in.  I have mapped them in the project setup per directions in the help files.  It worked fine in 2014 and I think I have set it up the same way in 2016 unless i am missing something.  Is anyone else having this problem?
2 REPLIES 2
in reply to: hwood818
Open your title block and note the name. Next go to your isoconfig.xml of the iso style you are using and insert that name into the "Symbol=" row under the TitleBlock node. See attachment.
Technology Administrators
AutoCAD Beta
